Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Problem of Qsys Design for D5m Camera on DE2-70
Hi, Guys.
i am working on video processing using d5m camera with de2-70. i am using qsys generation and nios 2 c code programming but i found a problem that altera does not hv pin planner pin for camera_if port. Is it a must to use verilog code to perform d5m camera set up?
Tags (1)
