Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Problem with ALTCLKCTRL module and outputs from two different PLLs in Cyclone III
Hello!
I'v got a Cyclone III device EP3C16U256. And i have got a two external clock signals 10 MHz and 30 MHz (they are connected to dedicated clock pins on different sides of FPGA). I want to make 120 MHz clock from 10 MHz clock and 120 MHz clock from 30 MHz clock. And i want to dynamicaly switch between them (120 MHz from 10 MHz and 120 MHz from 30 MHz).
I wrote this code:
... /*** PLL from 30 MHz to 120 MHz ***/ omsp_pll omsp_pll_inst ( .inclk0 ( mclk ), .c0 ( internal_ss_clk ) ); /*** PLL from 10 MHz to 120 MHz ***/ sync_pll sync_pll_inst ( .inclk0 ( sync_clk ), .c0 ( sync_ss_clk ), .locked ( sync_pll_locked_sig ) ); /*** ALTCLKCTRL module ***/ clk_mux clk_mux_inst ( .clkselect ( ss_clk_select_sig ), .inclk0x ( internal_ss_clk ), .inclk1x ( sync_ss_clk ), .outclk ( ss_clk_sig ) ); ...
And i have an error in Quartus (Quartus II 64-Bit Version 13.1.0 ):
--- Quote Start ---
Error (15669): inclk port of Clock Control Block "clk_mux:clk_mux_inst|clk_mux_altclkctrl_uhi:clk_mux_altclkctrl_uhi_component|clkctrl1" must be driven by 1 PLLs but is driven by 2 PLLs
Info (15670): Clock Control Block is driven by PLL "omsp_pll: omsp_pll_inst|altpll:altpll_component|omsp_pll_altpll:auto_generated|pll1"
Info (15670): Clock Control Block is driven by PLL "sync_pll:sync_pll_inst|altpll:altpll_component|sync_pll_altpll:auto_generated|pll1"
--- Quote End ---
How can i solve this problem?
Refer to Figure 5-1 'Clock Control Block' - page 5-5 - in chapter 5 of the 'cyclone iii device handbook (https://www.altera.com/literature/hb/cyc3/cyclone3_handbook.pdf)'.
Unfortunately, in Cyclone III at least, you're going to need an external loop, fed from one of your PLL outputs to a dedicated clock input pin associated with the Clock Control Block you're using. The Control Block is limited to using two (of the five available) clock outputs from a single PLL. There's no routing to allow a feed from a second PLL.
Cheers,
Alex
--- Quote Start ---
Cheers,
Alex
--- Quote End ---
Thank you very much for the detailed answer!
