21345 Discussions
Problem with uart and ethernet communication
I have same problem with uart communication.
I want receive data from ethernet and send to UART and vice versa.
UART to Ethernet is OK, but Ethernet to UART is not OK.
# define NETWORK_PORT 5000# define BUFFER_SIZE 32
# define true 1# define false 0
static char data_buffer[BUFFER_SIZE];
void DieWithError(const char *msg)
perror(msg);
exit(1);
int open_socket(void)
int listen_fd;
int incoming_fd;
struct sockaddr_in my_addr;
struct sockaddr_in other_addr;
//socklen_t other_addr_len;
int other_addr_len;
int yes = 1;
// create socket.
listen_fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
if(listen_fd == -1)
DieWithError("socket");
if(setsockopt(listen_fd, SOL_SOCKET, SO_REUSEADDR, &yes, sizeof(int)) == -1) {
DieWithError("setsockopt SO_REUSEADDR");
if(setsockopt(listen_fd, SOL_SOCKET, SO_KEEPALIVE, &yes, sizeof(int)) == -1) {
DieWithError("setsockopt SO_KEEPALIVE");
my_addr.sin_family = AF_INET;
my_addr.sin_port = htons(NETWORK_PORT);
my_addr.sin_addr.s_addr = INADDR_ANY;
memset(my_addr.sin_zero, '\0', sizeof(my_addr.sin_zero));
if(bind(listen_fd, (struct sockaddr *)&my_addr, sizeof(my_addr)) == -1)
DieWithError("bind socket");
printf("Listening on %s, port %d.\n", inet_ntoa(my_addr.sin_addr), ntohs(my_addr.sin_port));
// listen
if(listen(listen_fd, 1) == -1)
DieWithError("listen socket");
// accept connection.
other_addr_len = sizeof(struct sockaddr_in);
if((incoming_fd = accept(listen_fd, (struct sockaddr *)&other_addr, &other_addr_len)) == -1)
DieWithError("accept socket");
// close socket.
if(close(listen_fd) == -1)
DieWithError("close old socket");
printf("New connection from %s, port %d.\n", inet_ntoa(other_addr.sin_addr), ntohs(other_addr.sin_port));
return incoming_fd;
// close socket
void close_socket(int fd)
if(close(fd) == -1)
DieWithError("close socket");
// open uart.
int open_serialport(void)
int fd;
// open uart.
fd = open("/dev/uart", O_RDWR | O_NOCTTY | O_SYNC);
if(fd == -1)
DieWithError("open serialport");
return fd;
// close serialport
void close_serialport(int fd)
if(close(fd) == -1)
DieWithError("close serialport");
int fromuartTask(void)
int network_fd;
int serial_fd;
fd_set read_fds;
struct timeval tv;
int tmp;
// open uart and network connection
serial_fd = open_serialport();
network_fd = open_socket();
while(1)
FD_ZERO(&read_fds);
FD_SET(network_fd, &read_fds);
FD_SET(serial_fd, &read_fds);
tv.tv_sec = 0;
tv.tv_usec = 0;
// wait.
if(network_fd > serial_fd)
tmp = network_fd;
else
tmp = serial_fd;
if(select(tmp + 1, &read_fds, NULL, NULL, &tv) == -1)
DieWithError("select");
// Ethernet data ??
if(FD_ISSET(network_fd, &read_fds))
// recv from ethernet.
printf("wait for network data.\n");
tmp = recv(network_fd, data_buffer, BUFFER_SIZE, 0);
if(tmp == -1)
DieWithError("recv");
if(tmp == 0)
break;
// write to uart.
if(write(serial_fd, data_buffer, tmp) == -1)
DieWithError("write");
printf("Got network data.\n");
// Data from UART??
if(FD_ISSET(serial_fd, &read_fds))
// read from uart.
printf("waiting for serial data.\n");
tmp = read(serial_fd, data_buffer, BUFFER_SIZE);
if(tmp == -1)
DieWithError("read");
// send to ethernet.
if(send(network_fd, data_buffer, tmp, 0) == -1)
DieWithError("send");
printf("Got serial data.\n");
// close socket and serial port
close_socket(network_fd);
close_serialport(serial_fd);
return 0;
It was a long time age that I tried, but IIRC the select() call doesn't work well with the Interniche stack. It only detects incoming data on one of the sockets, but not both.
This was a long time ago (with Quartus 7.2 I think) so it may have been fixed since then. Otherwise you could try to use two threads to read data on each socket.
