21336 Discussions
Problems using command-line interface
I am fairly new to using Quartus. (using version 8.0) I have a project that Successfully compiles in the GUI. However, when I try to use quartus_map I get the following errors:
--- Quote Start ---
$ quartus_map fec_dsp_interface_pkg_top --source fec_dsp_interface_pkg_top.qpf --family=CYCLONEIII
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 8.0 Build 231 07/10/2008 Service Pack 1 SJ Full Version
Info: Copyright (C) 1991-2008 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Tue Jan 27 15:57:19 2009
Info: Command: quartus_map fec_dsp_interface_pkg_top --source=fec_dsp_interface_pkg_top.qpf --family=CYCLONEIII
Warning: Using design file fifo_controller.vhd, which is not specified as a design file for the current project, but contains definitions for 3 design units and 1 entities in project
Info: Found design unit 1: fifo_controller_pkg
Info: Found design unit 2: fifo_controller-behaviour
Info: Found entity 1: fifo_controller
Error (10481): VHDL Use Clause error at fifo_controller.vhd(93): design library "work" does not contain primary unit "dsp_register_pkg" File:
fifo_controller.vhd Line: 93
Error (10800): VHDL error at fifo_controller.vhd(93): selected name in use clause is not an expanded name File: fifo_controller.vhd Line: 93
Error (10481): VHDL Use Clause error at fifo_controller.vhd(94): design library "work" does not contain primary unit "dsp_status_register_pkg" File: fifo_controller.vhd Line: 94
Error (10800): VHDL error at fifo_controller.vhd(94): selected name in use clause is not an expanded name File: fifo_controller.vhd Line: 94
Error (10481): VHDL Use Clause error at fifo_controller.vhd(95): design library "work" does not contain primary unit "constants" File: fifo_controller.vhd Line: 95
Error (10800): VHDL error at fifo_controller.vhd(95): selected name in use clause is not an expanded name File: fifo_controller.vhd Line: 95
Error: Quartus II Analysis & Synthesis was unsuccessful. 6 errors, 1 warning
Error: Peak virtual memory: 173 megabytes
Error: Processing ended: Tue Jan 27 15:57:20 2009
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
--- Quote End ---
Any ideas would be appreciated as I am working to develop scripts around Quartus.
Thank you,
Tom
Why are you using all those command line arguments? The qsf file (which the qpf points at) has all the settings that you need, just run
quartus_map <projectfile.qpf>
in your script, (minus the <>)
Thank you, this seems to fix that. I was going verbatim from the Altera Command-Line Scripting documentation.
