You can ignore it unless you're already using the HPS to program the FPGA after it boots. Or pop out the SD card if you're booting from that.
You may refer to : https://www.intel.com/content/www/us/en/docs/programmable/683673/23-4/configuration-user-guide.html
regards,
Farabi
You don't need to include the HPS in a design. Just treat the device as a standard FPGA.
Ok , in this case should I prevent the linux OS to boot ?
Or , just ignore it and program the FPGA ?
Thx
ok will try and give a feedback on sunday
Thx !!
Hi kikoss,
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
