21602 Discussions
Programming Tool for EPM7064STC44-10N
ArjunGoel
We need to make a new program for EPM7064STC44-10N which operates on +5V. Changing the part or decreasing its voltage is not possible. We used Quartus around 7 to 8 years back when we did this initially. Current version does not support this part. Please guide us which development software we should use and where can we get it from. We already have the USB Blaster for programming.
ak6dn
Valued Contributor III
This is your lucky day.
QuartusII 13.0sp1 supports the MAX7000S series and is still available for download.
Get it here:
https://www.intel.com/content/www/us/en/software-kit/711791/intel-quartus-ii-web-edition-design-software-version-13-0sp1-for-windows.html
Farabi
MAX7000 and Quartus 13.0sp1 will be EOL with no technical support.
I would recommend you to migrate your design to our latest MAX10 for future design.
link :  https://www.intel.com/content/www/us/en/products/details/fpga/max/10.html
regards,
Farabi
ak6dn
Did you not read the OP's original post:  "We need to make a new program for EPM7064STC44-10N which operates on +5V. Changing the part or decreasing its voltage is not possible. "
None of the MAX2/5/10 offer 5V compatible I/Os.
Quartus 13.0sp1 is still available for download and it directly supports the MAX7000S series as the OP requires.
Farabi
If the signal is not high speed, you can use level shifter for 5V signals.
If the design use too many 5V signals, there is no other option than to upgrade the whole design.
This is just recommendation to make sure customers can keep up with the updated devices, because in future the support for 5V devices is very little to none.
regards,
Farabi
Farabi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
regards,
Farabi
