21335 Discussions
Programming multiple devices
I have a board that is set up for In-System programming using the USB blaster. It contains two EP3C16Q240's and a single EPCS16 for programming the devices. I followed all of the instructions in the Cyclone III manual and configured the programming chain as a master/slave AS device using the MSEL pins. My question is how do I program the EPCS16 if I have two different programming files (for the two FPGA's)? There does not seem to be a way to add two pof files into a single EPCS device using the Altera programmer.
I am sure I am missing something simple here
Any help will be appreciated
You need to create a multi-sof POF file. to program the EPCS.
In quartus go File->Convert Programming File
Here you can create POF file and add your master and slave SOF files to the stream.
Pete
--- Quote Start ---
Pete
--- Quote End ---
Thanks for your help Pete. I was able to program the EPCS
