21267 Discussions
Programming sof using different firmware
Chris039
The Quartus programmer requires the firmware to program the sof. Does Quartus utilize firmware content during the compilation?
FvM
Not quite clear which firmware you mean. Generally Quartus programmer doesn't use firmware, except for USB Blaster II. Its driver (not Quartus programmer) loads a firmware for USB Blaster microcontroller.
Chris039
The firmware is the device firmware used during the sof programming.  It is located in C:\intelFPGA_pro\23.1\devices\programmer\firmware.
Does Quartus use the information in the firmware during the compilation?
FvM
as far as I'm aware of, "firmware" folder isn't used by Quartus programmer and neither in compilation. It's a toolkit for debugging purposes. In previous Quartus versions, it's located at quartus/common/devinfo/programmer/firmware.
Chris039
What is the function of these zip files in the firmware folder ? Do we have any use case where the zip is being used?
NurAiman_M_Intel
  • May I know the reason on why you need to know this information?
Aiman
Chris039
Hi Aiman,
I just want to understand the usage of the firmware in this folder, when and how it is being used.
NurAiman_M_Intel
@FvM response is correct.
Additionally, we are unable to provide further information on this as this is confidential. Apologize for the inconveniences.
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
