21615 Discussions
Programming the Arria 10 GX FPGA Development Kit
BigSid
Can I program this kit's FPGA using a .sof file or do I need to first generate a .flash file? Please include instructions if a .sof file is sufficient. Thanks.
sstrell
All FPGAs can be programmed with a .sof file via the JTAG interface, either JTAG directly or usually using JTAG to USB conversion (USB Blaster).  You just use the standalone Programmer or the Programmer included with a full installation of Quartus.
BigSid
I'm using the Arria 10 GX FPGA Development Kit (DK-DEV-10AX115S-A) and trying to configure its FPGA (10AX115S2F45I1SG) with a .sof file and a USB Blaster cable. I get this:
 Error (209015): Can't configure device. Expected JTAG ID code 0x02E660DD for device 1, but found JTAG ID code 0x020A30DD. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
The FPGA listed on the device search of Quartus Prime Standard 23.1 gives the 10AX115S2F45I2SGES as being installed on the kit board:
Which device part number should I be using, 10AX115S2F45I1SG or 10AX115S2F45I2SGES? What is the cause of the error? Thanks.
sstrell
Did you auto select the device in the Programmer or manually select it?  Try manually selecting the device.
And show a screenshot of what the Programmer is showing you.
BigSid
I've selected both devices (different compilations) and selected the devices manually in the Programmer. Programming fails with either compiled .sof file.
Here's the programmer and error message with 10AX115S2F45I2SG selected:
Here's the programmer and error message with 10AX115S2F45I1SG selected:
Any ideas? Thanks.
NurAiman_M_Intel
The part number should be 10AX115S2F45I1SG.
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/arria/10-gx.html
  • Do you used .sof file for 10AX115S2F45I1SG?
  • When you click auto detect, what is showing? Kindly provide screenshot.
  • Can you also try the JTAG chain debugger and provide screenshot here?
  • Does this ever work before?
  • Have you followed the userguide for the dev kit?
Aiman
BigSid
  • Do you used .sof file for 10AX115S2F45I1SG? YES
  • Does this ever work before? NO
  • Have you followed the userguide for the dev kit? YES
BigSid
The error description I'm getting is this:
Code 0x020A30DD is for a 5M1270Z MAX V device. This is not the device I selected for the file (10AX115S2F45I1SG) and doesn't appear to be anywhere on the Arria 10 GX FPGA Development Kit I'm using. How is the programmer finding this?
NurAiman_M_Intel
Since you are using dev kit, there is a switch to disable the MAX V on the dev kit. Please disable the switch and try to configure again.
Please also try the JTAG chain debugger after disable MAX V.
Aiman
BigSid
I've put development board switch SW4-2 in the ON position to disable the MAX V in the JTAG chain as described in the kit user guide:
However, the programmer still fails to configure the Arria 10:
And the MAX V still shows up in the JTAG chain:
Any ideas? Thanks.
BigSid
Hi Aiman,
Here are the board's SW3-SW6 switch positions. SW4-2 is in the ON position yet the MAX V device is still in the JTAG chain. Can you provide any further assistance? Thanks.
sstrell
Just for shiggles, how about flipping SW4-1 and SW4-2 to their opposite positions and see if there's a change in the JTAG chain?
BigSid
Tried it. Programming still fails and same error message.
sstrell
But does the JTAG chain appear differently in either the Programmer or the JTAG Chain Debugger?
BigSid
NurAiman_M_Intel
May I know where you are from? We can set up a call to look at this case.
Me and my team are based in Malaysia.
Aiman
BigSid
I am in Massachusetts, USA.
BigSid
Hi Aiman,
Any progress with setting up a call?
BigSid
Hi Aiman,
NurAiman_M_Intel
I have sent the meeting invite.
Aiman
BigSid
Hi Aiman,
Thanks. I'll be on the call.
