20405 Discussions
Progress FAILED !!! on the programmer.
Hello Guys;
I have a problem, I can use Quartus Prime Lite Edition 15.1 so MY Project is created file that are .sof and .pof by Quartus Prime Lite Edition.
I want to program my evaluation kit , I open programmer and set up hardware setup. I can look USB-Blaster-II and my evaluation kit property so
I choose .sof file and click Start button. Progress is failed.
Why did programmer occur error?
WHAT should I do for programming file succesfully ??
Thank u .
Provide details about evaluation Kit, Device & Error.
Can you share a screenshot of the programmer?
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
Perform the following steps,
1. Visual check: Factory Default Switch and Jumper Settings, FPGA chip leads, LEDs status etc.
2. To successfully use the USB-Blaster cable, disconnect it before power up the board. Once you power on the board, then reconnect the USB-Blaster cable.
3. Open Quartus II Programmer
4. Click Auto Detect(or else Check Add Device->select 10M50DAF484 )
5. Add .sof file
6. Turn on Program/Configure option.
7. Click Start.
8. Check the nSTATUS, CONF_DONE, nCONFIG signal status.
Best Regards
Vikas Jathar
I exercised your steps but the error occur.
I add attachements, can u look it ?
Why did the error occur?
Does my cable be imcompatible ?
Thank u ...
Install the Intel FPGA Download Cable II since your screenshot showing Altera USB-blaster II unconfigured, Refer the following link,
https://www.altera.com/documentation/iga1446847781805.html
Try using another USB-Blaster II download cable as well.
Best Regards
Vikas Jathar
--- Quote Start ---
Best Regards
Vikas Jathar
--- Quote End ---
Thank u for helping me ;
But My computer's software is windows 10, I can try your exercises but I am looking the website for USB Blaster II, IT İS NOT SUPPORTED
Windows 10 :(
ı think It occur the error because of software , doesn't it ???
Well I have even the USB-Blaster (not the newer USB-Blaster II) running under Windows10. I just went to device manger, right click on the device, update driver, use driver on computer, point to the driver directory of the Quartus II Installation. That worked pretty well :-)
Thank u :) I will try it that is your actions :)
I hope , it will work
