21398 Discussions
Provide details for the - FFV1_ITEMMASTER_20240221
abraham1
​Below is the information needed as per request.
ITEM NUMBER: FFV1H-ICS-1080-00
MPN_DESCRIPTION: IC, FPGA, AGILEX 7-M, AGMG039R47A2E2V, MEDIUM SPEED, EXTENDED TEMP, BGA4700
MANUFACTURER PART NUMBER (MPN): AGMG039R47A2E2V
  1. ABOVE DESCRIPTION MATCHES WITH MPN ? (YES / NO) ?:
  2. GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT / INVALID ?:
  3. IS THIS MPN AVAILABLE IN TAPE & REEL PACKAGING OPTION ? (YES / NO) ?:
  4. IF YES, PROVIDE US CORRECT & ORDERABLE TAPE & REEL PART NUMBER ?:
  5. PROVIDE US CORRECT & ORDERABLE PART NUMBER FOR PURCHASE ORDER #PO's ?:
  6. LIFE CYCLE STATUS (ACTIVE / OBSOLETE / NRND) ?:
  7. PART MARKING ?:
  8. MOUNTING TYPE: SURFACE MOUNT TECHNOLOGY (SMT) ? (YES / NO) ?:
  9. MOISTURE SENSITIVITY LEVEL (MSL) ?:
  10. PACKAGING TYPE (TAPE & REEL, ROLL, TRAY, TUBE, AMMO, BULK etc.) ?:
  11. ROHS COMPLAINT ? (YES / NO) ?:
NazrulNaim_Intel
Good day
Thank you for reaching out. I'm Nazrul Naim looking into your issue and allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
NazrulNaim_Intel
Sorry for the delay. Below is the information needed as per request.
ABOVE DESCRIPTION MATCHES WITH MPN ? (YES / NO) ?: YES
GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT / INVALID ?: Correct & Orderable
IS THIS MPN AVAILABLE IN TAPE & REEL PACKAGING OPTION ? (YES / NO) ?: NO
IF YES, PROVIDE US CORRECT & ORDERABLE TAPE & REEL PART NUMBER ?: N/A
PROVIDE US CORRECT & ORDERABLE PART NUMBER FOR PURCHASE ORDER #PO's ?: AGMG039R47A2E2V
LIFE CYCLE STATUS (ACTIVE / OBSOLETE / NRND) ?: Active
PART MARKING ?:
MOUNTING TYPE: SURFACE MOUNT TECHNOLOGY (SMT) ? (YES / NO) ?: YES
MOISTURE SENSITIVITY LEVEL (MSL) ?: 3
PACKAGING TYPE (TAPE & REEL, ROLL, TRAY, TUBE, AMMO, BULK etc.) ?: TRAY
ROHS COMPLAINT ? (YES / NO) ?: YES
Hope that answers your question.
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
