21591 Discussions
Quartus 13.1 Internal error
RonenP
Hi
I am using Quartus II 64-Bit Version 13.1.4 Build 182 03/12/2014 SJ Full Version,
 and keep on getting the following error during fitting.
Internal Error: Sub-system: U2B, File: /quartus/db/u2b/u2b_translator_cv_hmc.cpp, Line: 1028
Invalid Accessor String: CDB_MEM_IF_TCWL_ENUM::TCWL_1
Stack Trace:
0x126842: U2B_TRANSLATOR_CV_HMC::translate_enum_params_generic + 0x2792
0x12b749: U2B_TRANSLATOR_CV_HMC::convert + 0x319
0x12de69: U2B_TRANSLATOR_CV_HMCPHYINT::convert + 0x319
0x2fab3: FSV_U2B_POSTFIT::check_u2b_configs_for_conflicts + 0x4c3
0x310fb: FSV_U2B_POSTFIT::work + 0x13b
0x1dac97: VPR_QI_FACADE::load + 0x2f97
0x19b6b1: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x185e71
0x1c5d52: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x1b0512
0x1d7cc7: VPR_QI_FACADE::vpr_qi_main + 0x27
0x2de91: fitapi_run_vpr + 0x71
0x1276f: fsv_initialize_fitter + 0x60f
0x13ce4: fsv_initialize_fitter + 0x1b84
0x15774: fsv_initialize_fitter + 0x3614
0x12102: fsv_execute + 0x22
0xbaf0: fmain_start + 0x830
0x1525: Legacy_fitter_Init + 0x4b5
0x2618: Legacy_fitter_Init + 0x15a8
0x2168: Legacy_fitter_Init + 0x10f8
0xf8a6: TclInvokeStringCommand + 0xc6
0x112a8: TclEvalObjvInternal + 0x328
0x121b5: TclEvalEx + 0x8d5
0x12d48: TclEvalObjEx + 0x2d8
0x1abbd: Tcl_EvalObjCmd + 0xfd
0x56917: TclExecuteByteCode + 0xe47
0xa2376: TclObjInterpProcCore + 0x76
0x7c117: Tcl_FSEvalFileEx + 0x1d7
0x7a626: Tcl_EvalFile + 0x36
0xc1ff: qexe_ipc_progress_bar_name + 0x12bf
0x11dd6: qexe_get_command_line + 0x1556
0x150d5: qexe_run_tcl_option + 0x585
0x1e03d: qcu_run_tcl_option + 0xb8d
0x156ed: qexe_process_cmdline_arguments + 0x54d
0x15851: qexe_standard_main + 0xa1
0xa7f8: msg_exe_fini + 0x58
0xaf3c: msg_exe_fini + 0x79c
0x1f04: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0xb8bf: msg_exe_main + 0x8f
0x17033: BaseThreadInitThunk + 0x13
0x52650: RtlUserThreadStart + 0x20
End-trace
Ronen
SyafieqS
Ronen,
Seem to me like a bug internal error. Possible to attach qar project here to be replicated?
RonenP
Hi
Thanks for your help
I have re-installed the Quartus. (Unfortunately didn't help much)
I have restored my project from a back up and it did the trick.
Now it seems to work fine.
Will try not to modify my IP's for now and hopefully it will stay stable.
Ronen
SyafieqS
Ronen,
Noted on that. May I know if there is any other concern?
