20260 Discussions
Quartus Build Crash - it used to compile
I have a Cyclone IV E design that used to build I was using signaltap and built a couple of debug load and now it's no longer able to compile.I removed the .stp and it still crashes, I removed and reinstalled the Quartus software - still crashes. Problem Details
Error:
*** Fatal Error: Access Violation at 0X000007FEB53FC717
Module: quartus_map.exe
Stack Trace:
0x7c716: sgn_source_file_processing + 0x68596 (synth_sgn)
0x7363b: sgn_source_file_processing + 0x5f4bb (synth_sgn)
0x7291a: sgn_source_file_processing + 0x5e79a (synth_sgn)
0x77a83: sgn_source_file_processing + 0x63903 (synth_sgn)
0x7bc2d: sgn_source_file_processing + 0x67aad (synth_sgn)
0x793bd: sgn_source_file_processing + 0x6523d (synth_sgn)
0x87da2: sgn_source_file_processing + 0x73c22 (synth_sgn)
0xbdf6d: sgn_create_qsys_generation_report + 0x6c4d (synth_sgn)
0xc8262: sgn_create_qsys_generation_report + 0x10f42 (synth_sgn)
0xc340b: sgn_create_qsys_generation_report + 0xc0eb (synth_sgn)
0x136b4: sgn_qic_full + 0x1b4 (synth_sgn)
0x1252c: qexe_apply_ini_vars + 0x245c (comp_qexe)
0x17872: qexe_process_cmdline_arguments + 0x2762 (comp_qexe)
0x18601: qexe_standard_main + 0xc1 (comp_qexe)
0xcbe8: msg_initialize_out_of_memory_handler + 0x378 (CCL_MSG)
0xe31c: msg_set_stack_size + 0x7c (CCL_MSG)
0x4c0c: mem_malloc_wrapper + 0x18c (ccl_mem)
0xc831: msg_exe_main + 0xa1 (CCL_MSG)
0x159cc: BaseThreadInitThunk + 0xc (kernel32)
0x5383c: RtlUserThreadStart + 0x1c (ntdll)
End-trace
Executable: quartus_map
Comment:
None
System Information
Platform: windows64
OS name: Windows 7
OS version: 6.1
Quartus II Information
Address bits: 64
Version: 15.0.0
Build: 145
Edition: Full Version
Have you tried trashing the db and incremental_db folders? Something may be corrupted in there.
