21602 Discussions
Quartus-Cannot load library error (tsm_ddrtcl.dll)
I`ve been getting this error below every time when I try to open quartus.I `ve reinstalled the program a few times.It did not solve the problem.When I open the program once after the reinstallment,it works good.Then I close it and try to open again,it does not.This makes me crazy because I have to finish a project soon.There`s no answer on google or altera`s website.How can find a solution? Have you encountered this error before?
( I cannot find that .dll file anywhere)
Internal Error: Sub-system: ATCL, File: /quartus/ccl/atcl/atcl_root.cpp, Line: 1776
Error found while sourcing: c:/altera/72/quartus/common/tcl/internal/init/ddr_timing_model.pkg_info
ERROR: Can't load library: c:\altera\72\quartus\bin\tsm_ddrtcl.dll. The operating system reports the following error: The specified module could not be found.
Stack Trace:
0xC22AE : MEM_MANAGER::s_quartus_memory_counter + 0x96B76 (netutils)
End-trace
Quartus II Version 7.2 Build 151 09/26/2007 SJ Web Edition
contact altera mysupport
or use a newer version of the tool, one that was released in the last 5 years?
--- Quote Start ---
--- Quote End ---
All right,
Thanks for replying.
--- Quote Start ---
All right,
--- Quote End ---
I have the same problem. The system displays a message :
Internal Error: Sub-system: ATCL, File: / quartus / ccl / atcl / atcl_root.cpp, Line: 989
Error found while sourcing: c :/ altera/13.0sp1/quartus/common/tcl/internal/init/ddr_timing_model.pkg_info
ERROR: Can't load library: c: \ altera \ 13.0sp1 \ quartus \ bin \ tsm_ddrtcl.dll. The operating system reports the following error: The specified module could not be found .
In fact, this file is present on the disk:
C: \ Altera \ 13.0sp1 \ quartus \ bin> dir tsm_ddrtcl.dll
13.06.2013 5:45 415744 tsm_ddrtcl.dll
Please help solve the problem and finish my project with Altera .
Note - reinstall the program has not solved the problem.
--- Quote Start ---
Stack Trace:
End-trace
--- Quote End ---
Maybe it helps for someone. Antivirus can cause this problem. You need to add this file to exclusions of your antivirus. You need to do it before you make the first launch of Quartus, otherwise antivirus can delete this file or add to the quarantine. My AVG does like this:)
Good luck
