21615 Discussions
Quartus II 18.1 lite edition in system memory editor
AGofs
Good afternoon ,
I'm working with 18.1  lite edition with my new FPGA design.
I can program FPGA successfully, and then  I'm opening  InSystem Memory Editor .
JTAG ready and USB-Blaster found.
I would expect to receive a lot of InSystem Memory Editor instances  ( as planned at the  my design).
but I'm getting warning :"No instance found".
There not a matter of the USB-blaster or SW, because I've got InSystem Memory Editor instances at the previous FPGA design with same USB-Blaster and same SW.
Where is  a problem?
sstrell
So in the IP Parameter Editor for the RAMs in your design, you've enabled ISMCE, specified a unique index name for each instance, compiled the design, and programmed the device.  Have you tried programming the device from within the JTAG Configuration section of the ISMCE instead of the Quartus Programmer?
AGofs
Good morning,
I've tried to program my device from  JTAG Configuration section of the ISME- sometimes it programs my device properly, but rarely (approximately 1 from 10 trials).
"programs my device properly"- means I've seen rising at the current consuming.
all another trials- any rising at the current consuming after device has been programmed.
in addition, when I'm using an "auto-detect" option at the programmer- it also programs my device properly, but not every time (approximately 1 from 4 trials).
ShengN_Intel
May be power cycle the board, recompile and reprogram the board. Did another run and see.
Sheng
AGofs
Hi Sheng,
I've made recompiling several times- any change at the behavior of the PCB.
you wrote:"May be power cycle the board".
what do you mean?
ShengN_Intel
Have you properly timing constraint the jtag? Template can be found by go to Insert Template -> Timing Analyzer -> SDC Cookbook -> Jtag Signal Constraints.
Or may be try to lower the programming frequency.
Sheng
AGofs
Hi Sheng,
I will check this issue, but I always used default constraints- and it works.
ShengN_Intel
what do you mean?
Turn off and on the board.
AGofs
It doesn't improve the performance of the board.
ShengN_Intel
Any further update or concern on this thread?
Sheng
AGofs
you can close the case.
thank you.
