21611 Discussions
Quartus-II Simulation WVF
I have done the simulation on other computer before, I installed Quartus on mine too. When I try to start simulation this little box supposed to appear and write what's the progress on starting the progress, opens and disappears in less than a second. Is there any log file for this I can check? I use Win10 and I use 64 bit version, Cyclone-III.
erm, I am not sure what you mean.
when you start the simulation I assume you expect the splash screen of Modelsim. I have never noticed a progressbar.
What do you want to do with the wvf?create it rerun??
--- Quote Start ---
--- Quote End ---
I just needed to run University Program WVF and see the output. But I fixed it. The problem is solved by installing quartus to C.
