21611 Discussions
Quartus Prime Pro crash-prone
Seadog
I keep getting this unwanted message:
I am running QPP 18.1 Build 222 09/21/2018 SJ Pro Edition, on windows 10. The crashes seem to occur most frequently when I am running Timing Analyzer.
AndyN
Try doing a Clean Project, then delete the qdb, output_files, and temp-clearbox folders. That usually does the trick...
Vicky1
"I keep getting this unwanted message:" please provide here the errors/ messages you observed.
In addition, Close the Quartus tool, delete the 'db' & 'incremental_db' folder from project directory then try to recompile & run timing analyzer.
Try to check at your end by creating new fresh project using these files.
Check the Quartus 18.1.2 updates from the 'Updates' tab from link below,
http://fpgasoftware.intel.com/18.1/?edition=pro
Vicky
Vicky1
Have you resolved the issue?
May I know any update?
Vicky
Seadog
Vicky,
I have not solved the issue. I have tried QPP 19.2, and it also has crashed in a similar manner. In this case, I was cross-probing from Timing Analyzer to Chip Planner (Locate Path-> Locate in Chip Planner).
I can delete the compiler output, but then I do do another build, which can take a couple of hours; so I am disinclined to do that very often.
Vicky1
"I keep getting this unwanted message:" please provide here the errors/ messages you observed. -------------- if you are able to reproduce please provide that message & screenshot.
'I have not solved the issue. I have tried QPP 19.2, and it also has crashed in a similar manner.' ---- what do you mean crashed ? what you observed exactly?
you can also check by fresh downloading & installing again Quartus prime pro 19.2, it might get corrupted the setup while downloading.
Vicky
Seadog
Here is a fresh dump from 18.1 Standard:
Problem Details
Error:
*** Fatal Error: Access Violation at 0X00007FF97361C778
Module: quartus.exe
Stack Trace:
0x6c777: ACVQM_OBJECT_INTERFACE::is_underlying_object_valid + 0xe7 (ACE_ACVQ_ACVQM)
0x2d25b: ACVQM_MAPPER::update_given_matrix + 0xcb (ACE_ACVQ_ACVQM)
0x9322f: ACVQM_OBJECT_GROUPING_MANAGER::modify_mapper_with_sets + 0x3ef (ACE_ACVQ_ACVQM)
0x9366e: ACVQM_OBJECT_GROUPING_MANAGER::modify_overlay_set + 0x12e (ACE_ACVQ_ACVQM)
0x8469f: ACVQM_COMMAND_MANAGER::highlight + 0x7f (ACE_ACVQ_ACVQM)
0x4ebbb: acvqc_highlight + 0x9b (ace_acvq_acvqc)
0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
0x17a65: TclEvalEx + 0xa65 (tcl86)
0x18257: Tcl_Eval + 0x37 (tcl86)
0x105e7: atcl_tcl_eval + 0x117 (ccl_atcl)
0x58cbb: ACVQV_LOCATE_HISTORY_VIEW::process_highlight + 0x35b (ACE_ACVQ_ACVQV)
0x517e5: ACVQV_LOCATE_HISTORY_VIEW::qt_static_metacall + 0x165 (ACE_ACVQ_ACVQV)
0x11c420: QMetaObject::activate + 0x520 (QtCore4)
0x160ff9: QAbstractItemModel::dataChanged + 0x39 (QtCore4)
0x4eb2c1: QStandardItemModel::itemChanged + 0x131 (QtGui4)
0x4ed588: QStandardItem::setData + 0x178 (QtGui4)
0x4ed5ea: QStandardItemModel::setData + 0x3a (QtGui4)
0x4f9c73: QStyledItemDelegate::editorEvent + 0x223 (QtGui4)
0x472579: QAbstractItemView::selectionModel + 0x109 (QtGui4)
0x46c0f2: QAbstractItemView::edit + 0xf2 (QtGui4)
0x46fd13: QAbstractItemView::mouseReleaseEvent + 0x183 (QtGui4)
0x4a5d09: QTreeView::mouseReleaseEvent + 0x39 (QtGui4)
0xbd835: AFCQ_TREE_VIEW::mouseReleaseEvent + 0x365 (GCL_AFCQ)
0x60794: QWidget::event + 0xd4 (QtGui4)
0x382676: QFrame::event + 0x36 (QtGui4)
0x47552c: QAbstractItemView::viewportEvent + 0x4ac (QtGui4)
0xc1656: AFCQ_TREE_VIEW::viewportEvent + 0x2b6 (GCL_AFCQ)
0x10f802: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0x82 (QtCore4)
0x22e81: QApplicationPrivate::notify_helper + 0xe1 (QtGui4)
0x21a8e: QApplication::notify + 0x71e (QtGui4)
0x10d92b: QCoreApplication::notifyInternal + 0x7b (QtCore4)
0x25cfe: QApplicationPrivate::sendMouseEvent + 0x1de (QtGui4)
0x856f0: QScrollBar::trUtf8 + 0x1440 (QtGui4)
0x890b1: QApplication::winMouseButtonUp + 0x2761 (QtGui4)
0xca65: DispatchMessageW + 0x6a5 (USER32)
0xc581: DispatchMessageW + 0x1c1 (USER32)
0x132802: QEventDispatcherWin32::processEvents + 0x3e2 (QtCore4)
0x80eb4: QApplicationPrivate::openPopup + 0x204 (QtGui4)
0x10a88b: QEventLoop::exec + 0x22b (QtCore4)
0x10ce6f: QCoreApplication::exec + 0xdf (QtCore4)
0x197b: qgq_main + 0x7b (quartus)
0x12e98: msg_main_thread + 0x18 (CCL_MSG)
0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x16660: mem_thread_wrapper + 0x70 (ccl_mem)
0x12761: msg_exe_main + 0xa1 (CCL_MSG)
0x24e7: WinMain + 0x127 (quartus)
0x1e58: __tmainCRTStartup + 0x148 (quartus)
0x17973: BaseThreadInitThunk + 0x13 (KERNEL32)
0x6a270: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 18.1.0
Build: 625
Edition: Standard Edition
Vicky1
Thanks for the update.
it seems to be a bug but I`m not sure, Could you please provide the project (*.qar)file (Project Menu-> Archive Project...) for replication purpose?
Vicky
Seadog
I can't post a design to the forum, no.
Vicky1
Hello Daniel,
I checked in knowledge database, I couldn`t find the any entry for Quartus crashes by running the timing analyzer.
we(Intel support team) are checking internally so once I got any update I`ll update you.
Thanks for your cooperation & patience.
Vicky
Seadog
Vicky,
Here is another crash dump, this time from QPP 18.1; this occurred while I was cross-probing from Timing Analyzer to Chip Planner:
Problem Details
Error:
*** Fatal Error: Access Violation at 00007FF984EB0B90
Module: qpro.exe
Stack Trace:
0x70b8f: ACVQM_OBJECT_INTERFACE::is_underlying_object_valid + 0xdf (ACE_ACVQ_ACVQM)
0x2947b: ACVQM_MAPPER::update_given_matrix + 0xcb (ACE_ACVQ_ACVQM)
0x98d11: ACVQM_OBJECT_GROUPING_MANAGER::modify_mapper_with_sets + 0x3f1 (ACE_ACVQ_ACVQM)
0x990fe: ACVQM_OBJECT_GROUPING_MANAGER::modify_overlay_set + 0x12e (ACE_ACVQ_ACVQM)
0x8a2ef: ACVQM_COMMAND_MANAGER::highlight + 0x7f (ACE_ACVQ_ACVQM)
0x3f9db: acvqc_highlight + 0x9b (ace_acvq_acvqc)
0x16442: TclNRRunCallbacks + 0x62 (tcl86)
0x17c4d: TclEvalEx + 0x9ed (tcl86)
0x18437: Tcl_Eval + 0x37 (tcl86)
0x11555: atcl_tcl_eval + 0x125 (ccl_atcl)
0x5a993: ACVQV_LOCATE_HISTORY_VIEW::process_highlight + 0x333 (ACE_ACVQ_ACVQV)
0x55ed2: ACVQV_LOCATE_HISTORY_VIEW::dataChanged + 0x52 (ACE_ACVQ_ACVQV)
0x5b558: ACVQV_LOCATE_HISTORY_VIEW::qt_static_metacall + 0xe8 (ACE_ACVQ_ACVQV)
0x1de156: QMetaObject::activate + 0x576 (Qt5Core)
0x180c8e: QAbstractItemModel::dataChanged + 0x3e (Qt5Core)
0x29c8b8: QStandardItemModel::itemChanged + 0x1d8 (Qt5Gui)
0x29eefb: QStandardItem::setData + 0x31b (Qt5Gui)
0x29ef9a: QStandardItemModel::setData + 0x3a (Qt5Gui)
0x2516fd: QStyledItemDelegate::editorEvent + 0x25d (Qt5Widgets)
0x23897c: QAbstractItemView::selectionModel + 0x19c (Qt5Widgets)
0x231e86: QAbstractItemView::edit + 0xd6 (Qt5Widgets)
0x235f3f: QAbstractItemView::mouseReleaseEvent + 0x16f (Qt5Widgets)
0xb8d04: AFCQ_TREE_VIEW::mouseReleaseEvent + 0x364 (GCL_AFCQ)
0x3a66b: QWidget::event + 0xdb (Qt5Widgets)
0xdb006: QFrame::event + 0x36 (Qt5Widgets)
0x23bfe8: QAbstractItemView::viewportEvent + 0x318 (Qt5Widgets)
0xbc578: AFCQ_TREE_VIEW::viewportEvent + 0x2a8 (GCL_AFCQ)
0x1c0e8c: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0xdc (Qt5Core)
0x18d7b: QApplicationPrivate::notify_helper + 0x12b (Qt5Widgets)
0x1699c: QApplication::notify + 0x8dc (Qt5Widgets)
0x1beab8: QCoreApplication::notifyInternal2 + 0xb8 (Qt5Core)
0x1a0d5: QApplicationPrivate::sendMouseEvent + 0x325 (Qt5Widgets)
0x62898: QSizePolicy::QSizePolicy + 0x2d18 (Qt5Widgets)
0x6060d: QSizePolicy::QSizePolicy + 0xa8d (Qt5Widgets)
0x18d8f: QApplicationPrivate::notify_helper + 0x13f (Qt5Widgets)
0x17c16: QApplication::notify + 0x1b56 (Qt5Widgets)
0x4cc00: QGuiApplicationPrivate::processMouseEvent + 0x870 (Qt5Gui)
0x345fa: QWindowSystemInterface::sendWindowSystemEvents + 0x9a (Qt5Gui)
0x2084e4: QEventDispatcherWin32::processEvents + 0xd64 (Qt5Core)
0x207cb5: QEventDispatcherWin32::processEvents + 0x535 (Qt5Core)
0x4ff88: qt_plugin_query_metadata + 0x1d18 (qwindows)
0x1ba982: QEventLoop::exec + 0x1b2 (Qt5Core)
0x1bd713: QCoreApplication::exec + 0x143 (Qt5Core)
0x10bb: qgq_main + 0x8b (qpro)
0x13e58: msg_main_thread + 0x18 (CCL_MSG)
0x1516e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x1f900: mem_thread_wrapper + 0x70 (ccl_mem)
0x1348e: msg_exe_main + 0xae (CCL_MSG)
0x20c3: WinMain + 0x153 (qpro)
0x16d2: __scrt_common_main_seh + 0x116 (qpro)
End-trace
Executable: qpro
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Address bits: 64
Version: 18.1.0
Build: 222
Edition: Pro Edition
Vicky1
Seadog
I have been getting this crash in or when cross-probing to chip planner, but at least lately I have only been running chip planner after doing a complete build (I am generally just pushing the compile button), as I am chasing timing closure. And I have seen the same (or very similar) behavior in QPS 18.1, QPP 18.1, and QPP 19.2. I know Standard and Pro have different compilers, but I suspect the chip planner and perhaps timing analyzer are the same for both tools. It seems most likely a common feature is causing similar problems in both tools.
JosephC_Intel
Hi Daniel,
From what being share by Vicky on his last comment on the KDB, do this give you a better picture on how to avoid such crash or error?
We do have same issue reported internally but once we put chip planner as last step during compilation, the standard operation instruction should complete.
Let us know if you still need further support or if we are OK to close this issue for now.
Joseph
JosephC_Intel
Hi Daniel,
Can we get some updates here? If further help is required, we can submit this case to engineering.
So, please update us your status.
Joseph
