20702 Discussions
Quartus Prime Standard 15.1 - Missing Arria 10 compatible IP in Catalog
Hi all,
I have just installed Quartus prime standard 15.1 and am starting a project using an Arria 10 board. I need to use the IP catalog (for PLLs specifically) but there is no IP compatible with the Arria 10 for some reason. The project was previously based on a Cyclone V FPGA on the lite edition but I have changed the device settings. All the other IP for other devices are available. Any ideas as to what's wrong??
Dáire.
Hello dcanavan,
Did you install the .QDZ for Arria when you installed quartus ?
You have to install these libs separately for each family.
Sometimes boards come with golden reference design examples, there is a directory IP in these examples, if you copy the contents of these directories to your project ip directory (or create one) you can go a long way.
Johi.
