Programmable Devices
20957 Discussions
Quartus programmer software for 32-bit PC
Where can I get Quartus II software version 14.02 32-bit installer?
Reimo
Thanks for the replay, but this installer is for 64-bit.
13.0sp1 readme.txt release note indicates Win7 32b is a supported install target for the Lite/Free tool. I know this because I have it installed on my system.
On Altera's info page: https://www.altera.com/support/support-resources/download/os-support.html
From the table footnotes. I highlighted a couple of items.
  • starting with acds v14.0, intel fpga software only supports 64 bit versions of the os listed in table 1, unless specified.
  • The 32 bit library files are required to run the software on Linux* 64 bit platforms.
  • Windows 8.0 only.
  • Both 32 bit and 64 bit are supported.
  • Only KDE desktop manager is supported.
  • 32-bit standalone programmer is only supported in standard edition.
So if you use a PAID version of the tools it appears a 32b version of the standalone programmer tool is supported.
Otherwise it appears you must use 13.0sp1 or earlier to get a free 32b programmer tool.
Many thanks for the detailed explanation, I think that easiest way for my is to buy new laptop with 64-bit version.
Byunjr
