20728 Discussions
Quartus13.1 Fatal Error, when generate .sof
I compile the project, the quartus shows it already pass synthesis and fitter successfully,
the error shows when generate programming files, error message is show as follow:
the quartus versions I use is 13.1 and FPGA is 5CGXFC7D6
https://alteraforum.com/forum/attachment.php?attachmentid=15088&stc=1
https://alteraforum.com/forum/attachment.php?attachmentid=15089&stc=1
anyone knows what's the reason cause this problem and how to solve it?
Thanks in advance.
Qi
Can you tell about your design?
The error may be because of logical issues.
Or
Try a different version of Quartus.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
this project is:
1. transmit 8 channels lvds signals (200M) out to daugther board, use ALTLVDS_TX ipcore;
2. receive 8 channels lvds signals (200M) in from daugther board, use oversampling logic;
3. collecting 8 channels data and transmit to PC by cameralink;
4. other modules all some data processing;
is this enough?
Try deleting the db and incremental_db directories and then recompiling. Something could just be corrupted.
