21325 Discussions
Quartus8.1 Warning: A strange waring
Recently when I open a revision project in Quatus 8.1,which I founded in the Quartus7.2,there is a strange waring appears:
Warning: Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details.
But this is the only one warning after the whole compilation, I didn't see any other warings in the messages.Moreover, I have already assigned all the pins in the Pin Planner that I used.
When I turned to Quartus8.1 Help, it says that :
CAUSE:There are one or more pins with incomplete I/O assignments. The I/O Assignment Warnings report section in the Fitter compilation report lists the affected pins and the missing I/O assignments.ACTION:Use the Assignment Editor or the Pin Planner to add the missing I/O assignments to the affected pins.
I searched the messages, but didn't found anything that I can used to correct my setting.
The device that I used is Cyclone III EP3C10E144c8, I used the classic timing analyzer for timing analysis in the design(with no constraints),and I nearly did not make any changes to the QuartusII default settings.
I have searched the problem for about four days, but I still didn't get anything.
Yesterday, I have download a design examples from Altera web site:
http://www.altera.com/literature/lit-an.jsp,
AN 522: Implementing Bus LVDS Interface in Cyclone III, Stratix III, and Stratix IV Devices.
I have complied the design examples on my computer in QuartusII 8.1, and I still found the waring that I mentioned.
I don't know why?
I would be very grateful if anyone could give me some suggestions.
The incomplete I/O warnings are not listed with the other warnings. You manually need to go into the fitter report and select "I/O Assignment Warnings report". You should then see the list of missing assignments.
Thank you for your replay.
I have searched "Fitter settings" dialogue,and the complaintion report, but didn't find anything that you mentioned.
Would you please explain more clearly where I can select "I/O Assignmnet Warning report", I coundn't find it in Quartus8.1 software.
Thank you very much, again.
I made a screenshot. You need to look in the compilation report, not the settings.
Hope this helps!
(click for a larger version)
http://static.becoz.org/img/iowarnings-small.png (http://static.becoz.org/img/iowarnings.png)
Thank you for your help. You are a kind man.
I have found it in QuartusII software and solved my problem.
Thank you again.
