21594 Discussions
QuartusII 13.0 internal error
Tarshin
I have tried to reinstall Quartus, but the error still happens when "Start Compilation".
Meanwhile, I cannot find the atcl_tcl.cpp which is reported error below, so it is a little bit strange.
The error log is shown below:
Internal Error: Sub-system: ATCL, File: /quartus/ccl/atcl/atcl_tcl.cpp, Line: 197
interp != NULL && package && *package
Stack Trace:
0x25bd: err_report_internal_error + 0x2d
0x2977e: atcl_package_require + 0xd1e
0x3a2d0: ACF_MANAGER_FACTORY::delete_manager + 0xc430
0x2a9bb: ACF_MANAGER::internal_open_create_project + 0xa5b
0x2b824: ACF_MANAGER::open_project + 0x814
0x11f08: qexe_get_command_line + 0x1ad8
0x14e0e: qexe_process_cmdline_arguments + 0x59e
0x14f21: qexe_standard_main + 0xa1
0x4ae8: msg_exe_fini + 0x58
0x522c: msg_exe_fini + 0x79c
0x1524: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5e0f: msg_exe_main + 0x8f
0x17033: BaseThreadInitThunk + 0x13
0x52650: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.0.0 Build 156 04/24/2013 SJ Full Version
Tarshin
I found the solution.
Clear the file .\incremental_db\compiled_partitions and then "Start Compilation". All the things go well!
The reason might be the sync error of the Onedrive which will create two conflicting files.
Tami
Hey there i get a similar error when i try to open quartus. How do i clear that file? Where can i find it? Thanks in advance for your help.
KennyTan_Altera
Good to know that this had been resolve, we shall close this thread. If you still need further assistance, you are welcome to post a response within 15days or open a new thread, some one will be right with you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
