19989 Discussions
Question about MAX10 FPGA's specification on using Altera Dual Configuration IP Core.
YSaka7
I want to reconfiguration MAX10(10M08DAU324I7G) FPGA with selecting configuration image0/1.
step1. Write register of IP Core Avalon-MM Address Map Offset:0 Bit:1=config image0/1 Bit:0=1(trigger)
step2. Wait busy signal de-asserted.
step3. ReConfiguration start.
When busy signal never de-assert, I want to abort process step2.
Please teach me maximum time (or clock cycle) of write register to busy signal de-asserted.
JohnT_Intel
Hi, I don't think you are able to observed the busy signal de-asserted as the device will start reconfiguration whenever you trigger it. This is almost similar to nConfig where it will be directly reconfigure the FPGA
YSaka7
Thank you for your reply.
Sorry, I was wrong.
I made a mistake in writing step1.
A correct question is as follows.
step1. Write register of IP Core Avalon-MM Address Map Offset:1 Bit:1=config image0or1 Bit:0=1(trigger)
It writes in the datasheet(Intel MAX10 FPGA Configuration User Guide Table34.) so.
The busy signal is generated right after the write cycle, while the configuration
image information is registered. Once busy signal is high, writing to this address
is ignored until the process is completed and the busy signal is de-asserted.
I think I have to wait busy signal de-asserted after set config_sel before set trigger reconfiguration.
JohnT_Intel
Yes, your understanding is correct. If you only performed config_sel then yes, you will need to wait for busy signal to be de-asserted before triggering reconfiguration.
