Programmable Devices
20704 Discussions
Questions about RapidIO II IP core
eagles
Hello!
I am trying to use Rapidio II IP core to establish SRIO communication between FPGA and DSP. Here are some questions I have met:
Question 1
Are these signals used by users to transmit data packets?
Question 2
I notice that these signals belongs to an avalon-st sink. Should I create an avalon-st source by myself to send the data packets to him? If so, must this avalon-st source be created by Qsys or platform designer?
Question 3
The signal gen_tx_data is 128bits. Is the maximum bit width of a data packet only 128 bits?
Paveetirra_Srie
Below is the answers for your questions:
  1. Yes, those are the Pass-Through Interface Signals
  2. The Avalon-ST pass-through interface is an optional interface that is generated when you select the Avalon-ST pass-through interface in the Transport and Maintenance page of the RapidIO II parameter editor.
  3. Yes, only 128 bits.
For more details, please refer to Rapid IO II UG.
https://www.intel.com/content/www/us/en/docs/programmable/683444/20-3/avalon-st-pass-through-interface-91575.html
Pavee
Paveetirra_Srie
Pavee
Paveetirra_Srie
Just wanted to check with you, is your concern has been addressed?
If yes , kindly do let me know.
Thank You
Pavee
eagles
My questions has already solved because of your answer. I've already accepted your solution.
Thank you very much!
Paveetirra_Srie
I’m glad that your question has been addressed, I now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Otherwise, the community users will continue to help you on this thread.
Thank you.
