1. Why do we need BAR in PCIe?
2. Why do we need multiple BARs in PCIe? 3. How do we choose type of BAR in PCIe? (64 bits/34 bits, Prefetchable/non-prefetchable) 4. With multiple devices (a RAM, a FIFO, a DMA and few I/O Registers) connected to PCIe, how do we know which BAR to connect to which device? Thank you, RanmuLink Copied
BAR stands for Base Address Memory and you use them as a reference address when you want to access for example a PIO component from your software.
You decide which BAR will be connected to which device. Dont forget that you will use these addresses when you will write your driver.- Mark as New
Dear Tonisss,
Thank you for the reply. It helps me to understand more about PCIe. Thank you again, Ranmu
