21592 Discussions
RS-232 PC Connection
I'm working in a Altera DE2-70 board and I need to make a connection to the PC using the RS-232 Serial Port. My question is if I can connect the board directly to the PC or I need to make a external circuit for make this connection.
I already know the board uses a ADM3202 transceiver chip for RS-232 communication, this chip converts the voltages between board and PC?
Simply use a straight RS-232 cable to connect the board to a PC.
