Programmable Devices
21327 Discussions
RTL Viewer -> how report a net/signal connectivity through hierarchies
amildm
Valued Contributor I
Hi All,
How to report a net/signal connectivity through hierarchies?
How to report the drive/driven logic of the net/signal?
Thank you!
sstrell
You can right-click any net or object in the RTL viewer and filter on the source, destination, or both of the selected item.  Is that what you're looking for?
amildm
yes, I'm getting a graphical representation of RTL with a sources and destinations of the given signal... But could I also get a textual report about all these source and destination signals?  I'm about the back/forward tracing report for the given signal.
sstrell
Textual report?  Not sure what you mean.  Like a list of sources or destinations?  View menu -> Properties.
amildm
No, 'View -> Properties' only shows the properties of the selected object, it doesn't list the "sources and destinations".
Under "Textual Report" I meant a list of the "sources and destinations" in the text format.
amildm
still waiting to somebody response.... how to generate a textual (text file) report attached find all the sources (drivers) and destinations (leaf logic) from the RTL viewer... Does Quartus support this feature?
ShengN_Intel
Hi amildm,
Can't find any related feature for that. Most likely the feature you mentioned above is not supported by Quartus yet.
Sheng
