Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Reference design (RapidIO) with errors ??
I have found the following reference design for RapidIO.
https://www.altera.com/downloads/thank-you.html?swcode=www-ref-srio-6488
This reference can really help me because I was looking for a reference (for Linux actually, I don't know which OS fits for this refence , yet it can also help if it works).
It seems that (maybe) there are missing files for this reference:
I have found srio_main_full.c, but I can't find many symbols such as :
TX_DATA_BASE, RX_DATA_BASE, and many more...
I also find it strange to see that the DMA destination is 0 (?) according to these lines:
//dest_buffer = (int *)RAPIDIO_IO_WRITE_SLAVE_BASE;
dest_buffer = 0x00000000;
I have also found a pdf explaining the reference design:
https://www.altera.co.jp/content/dam/altera-www/global/ja_jp/pdfs/literature/an/an568.pdf
Yet, I still don't understand how the dma operations here are responsible for rapidIO transaction:
pkt_id = 0;
IOWR_32DIRECT(STATS_BASE, 0, 0x00000010); // turn off shadow transfer in stats module
IOWR_32DIRECT(DMA_WRITE_BASE, 24, 0x00010000); // bit 16 = soft_reset
IOWR_32DIRECT(DMA_WRITE_BASE, 24, 0x00000000); // bit 16 = soft_reset
IOWR_32DIRECT(DMA_READ_BASE, 24, 0x00010000); // bit 16 = soft_reset
IOWR_32DIRECT(DMA_READ_BASE, 24, 0x00000000); // bit 16 = soft_reset
... // limit targeted address space to 2**16-1
target_address = (pkt_id & 0x0000ffff) * (payload);
//printf("target address : %x \n", target_address);
// setup the DMA write operation
IOWR_32DIRECT(DMA_WRITE_BASE, 4, (int)tx_data);
IOWR_32DIRECT(DMA_WRITE_BASE, 8, (int)target_address);
IOWR_32DIRECT(DMA_WRITE_BASE, 12, payload); // page size length register in dma
// not needed since enable_soft_burst is zero
// IOWR_32DIRECT(DMA_WRITE_BASE, 16, payload/4); // stride in cycles
// bit 0 is the continuous mode operation
// bit 1 is enable_soft_burst
// bit 2 is
// bit 3 is the go bit
IOWR_32DIRECT(DMA_WRITE_BASE, 24, 0x8); // go_bit=1, enable_soft_burst=0, continous mode=0
// setup the DMA read operation
IOWR_32DIRECT(DMA_READ_BASE, 4, (int)target_address);
IOWR_32DIRECT(DMA_READ_BASE, 8, (int)RX_DATA_BASE);
IOWR_32DIRECT(DMA_READ_BASE, 12, payload);
// wait for write dma to complete
rdata = IORD_32DIRECT(DMA_WRITE_BASE, 0);
wr_dma_done = (0x00000001 & rdata) == 0x00000001;
//printf("waiting for write dma done \n");
while(!wr_dma_done){
//printf("write dma base 0 %x \n", rdata);
//printf("write dma done \n");
// clear write done bit
IOWR_32DIRECT(DMA_WRITE_BASE, 0, 0x0);
Does anyone knows ?
Thank you,
Ran
