21615 Discussions
Remote JTAG Server
Chen_feng7
Hi
I'm setting up my remote lab with a JTAG server,
I`m using Intel® Quartus® Prime software over TCP/IP to connect remote FPGA devices,
I would like to know if there is a data transfer when configuring the FPGA,
If there is a data transfer, what is the amount of data transferred?
I want to calculate the maximum number of devices that can be used concurrently under the condition of 100M network bandwidth.
Thanks & Regards,
YuanLi_S_Intel
For sure there is data transfer over TCP/IP when you are configuring remotely. However, we do not measure this and this is really depending on the speed of the network. I would suggest you to test it with your setup.
YuanLi_S_Intel
Chen_feng7
I`ll try it
Thanks for your help!
