20693 Discussions
Replacement of EPCS with EPCQ-A (EPCS4SI8 to EPCQ4ASI8N)
FPGA56
Since the EPCS line of products is now obsolete, I will be replacing them with EPCQ-A chips. Are there any changes to the hardware that need to be made to accommodate the new chips, or can they be placed directly on the EPCS footprints? How will JIC programming work since the device doesn't show up when converting .SOF to .JIC? (Cyclone II device on Quartus II 13.0)
The pin layout is identical, so am I correct in assuming that after changing the footprint to EPCQ-A, no other changes have to be made?
Any help would be appreciated! Thanks
Maria_R_Intel
Hello FPGA56,
Thank you for posting on the Intel* Community.
We will move your thread to the proper sub-forum, please expect a response soon.
Maria R.
JohnT_Intel
If you are using the same package then it is a direct migration. For jic file, please refer to AN822 (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an822.pdf)
