21489 Discussions
Replacement of EPCS with EPCQ-A (EPCS4SI8 to EPCQ4ASI8N)
FPGA56
(Repost in a more relevant subtopic)
Since the EPCS line of products is now obsolete, I will be replacing them with EPCQ-A chips. Are there any changes to the hardware that need to be made to accommodate the new chips, or can they be placed directly on the EPCS footprints? How will JIC programming work since the device doesn't show up when converting .SOF to .JIC? (Cyclone II device on Quartus II 13.0)
The pin layout is identical, so am I correct in assuming that after changing the footprint to EPCQ-A, no other changes have to be made?
Any help would be appreciated! Thanks
NurAiman_M_Intel
Thank you for contacting Intel community.
Kindly refer to device migration guidelines below for the comparison and steps:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an822.pdf
Aiman
