21618 Discussions
Request for the Product Lifecycle Status
Jayaram1
Please provide us the Lifecycle status for the below requested part numbers.
If the Part is Active/In Production, kindly provide the YTEOL (Year to End of Life) and RoHS Compliance status.
If the Part is Obsolete/EOL, kindly provide the LTB (Last Time Buy), also suggest the Replacement Part with the YTEOL and RoHS Compliance details.
SSDSC2BA100G301
CM80616003060AES LBTD
733284-006
EPM3064ATC44-7N
EPM3064ATC100-10N
EPM3128ATC144-7N
EPF10K10AQC208-2N
EPF10K30AQC240-2N
EPF10K100EQC240-1N
EPM3064ATC44-10N
EPM3256ATC144-10N
EPM3256ATC144-7N
lixy
Hi Jayaram1,
733284-006,
For this Part Number, I could not find the exact product it is referring to. Could you check again whether it is Intel product and give a rough description what it is, so that we can try to check it again?
EPF10K10AQC208-2N,
This part number does not appear to be in our documents, but only EPF10K10AQC208-2. Could you confirm again the Part Number?
Except for these 2 part numbers, other products listed are discontinued. Please refer to the following PDN documents for Last Product Discontinuance Order Date. For applicable replacement product, there's no direct suggest we can give in the PDN document. If you would like to understand the exact device you can use for replacement, you may need to raise separate questions for CPU and FPGA/CPLD products, along with a general description of your application.
SSDSC2BA100G301,
https://www.intel.com/content/www/us/en/content-details/799660/intel-r-ssd-dc-s3700-series-100gb-200gb-400gb-800gb-pcn-113719-00-product-discontinuance-end-of-life.html
CM80616003060AES LBTD,
https://www.intel.com/content/www/us/en/content-details/804922/select-intel-atom-r-intel-r-core-2-quad-intel-r-core-2-duo-intel-r-celeron-r-intel-r-celeron-r-m-intel-r-pentium-r-intel-r-core-i7-860-intel-r-xeon-r-intel-r-core-i5-750-intel-r-core-i3-540-and-intel-r-core-i5-660-pr.html
EPM3064ATC44-7N, EPM3064ATC100-10N, EPM3128ATC144-7N, EPM3064ATC44-10N, EPM3256ATC144-10N, EPM3256ATC144-7N
https://www.intel.com/content/www/us/en/content-details/677620/product-discontinuance-notification-pdn1709.html?DocID=677620
EPF10K10AQC208-2, EPF10K30AQC240-2N, EPF10K100EQC240-1N,
https://www.intel.com/content/www/us/en/content-details/677693/product-discontinuance-notification-pdn1619.html?DocID=677693
Xiaoyan
