Hi Team ,
we required the below part for one of our running parts please let me know the availability
Mfr Name | MPN | Total Quantity |
Intel | EPM7064SLC84-10 | 5000 |
Thank you for contacting Intel community.
Please be noted that the part number mention was EOL since 2017. Kindly refer to PDN1619;
Aiman
As noted that MAX7000 part went EOL about 5 years ago.
However, there is a pin and functional compatible drop in replacement offered thru MicroChip/Atmel.
It would be the ATF1504AS-10JU84 which is still a production part.
However, lead time is currently quoted at 94 weeks thru several distributors (Mouser, DigiKey).
So even tho it is not EOL like Intel/Altera, it is basically unobtainable in the next year or two.
You can use the MicroChip/Atmel POF2JED tool to convert an Altera .pof file to the required .jed file for programming the Atmel device.
So it is a technical solution as a drop in equivalent part, but in practice may be nonviable because of market conditions.
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
