21492 Discussions
S10 Device Pin status
GDeXi
       MSEL1 and MSEL2 are both external 4.7K resistor pull-downs, but measured as 1.8, look at s10 pcg doc, there is an internal 25K pull-up, according to my understanding should be between 1.8 and 0。
 IO_AUX_RREF external 2.8K pull-down, RREF_SDM external 2K pull-down, but the test is about 500mv, this is normal? Or the wrong design.
YuanLi_S_Intel
Hi Guo DeXin,
Perhaps you will need to check your board signal integrity. In S10, pin connection guidelines, it is recommended to route in a way that no aggresor on this. More over, it is a reference resistor pin, is a input pin instead.
Thank You.
GDeXi
upload image about  IO_AUX_RREF  and RREF_SDM
Tks for your help!
YuanLi_S_Intel
Hi DeXin,
Apologize i dont really understand the question. Are you saying that the output voltage observed with external 2.8K pull down, the voltage is 500mV and this is abnormal?
Thank You
User1574410249703619
Yes,The pin IO_AUX_RREF   and RREF_SDM , the voltage is 500mV and this is abnormal?
GDeXi
is there someone to help me ?
YuanLi_S_Intel
Hi Guo DeXin,
Thank You.
