21336 Discussions
SDRAM Controller SDC Constraints
When using SDRAM Controller are SDC Constraints relative to SDRAM needed?
Thank you
Yeah, unfortunately the Altera SDRAM controller does not seem to create timing constraints like the DDR2/DDR3 IP core does.
I wrote some constraints for the DE0-nano SDRAM that are also valid for the SDRAM used on some of the other Terasic DE-series boards.
See the example design and SDC file posted in this thread;
http://www.alteraforum.com/forum/showthread.php?t=45927
Cheers,
Dave
Thank you very much for the example. Altera should document better their ip-core.
