21335 Discussions
SRAM Read Question
Am using TerASIC DE2-115. SRAM is asynchornous 10ns ISSI. Have Nios CPU and custom interface (TDR) multiplexed to SRAM. CPU interface works perfectly. However, when I try to read SRAM from TDR interface, the readdata component always reports the previous address's data, not the current. Clock is 100Mhz and I currently have 3 wait states set between activating the read and reading the data. Have also tried setting WS to 10. Results are different, but still incorrect. It seems that once the control and address lines are set, and after 10ns, the readdata should become, and remain, valid until I dectivate the control lines.
Below is SRAM interface and the TDR interface controlling it. I've excluded some of the control logi (cpu_tdr_sel, etc.) Would appreciate any thoughts on my mistake. It seems that since I am at 100Mhz 3 WS would be more than sufficient. Also, from the ISSI datasheet, it appears that I should be able to set all control (WE,OE,CS,UBE,LBE) and address lines at the same time.
Apologies for lengh post...
RT
/********* SRAM Interface *************/
reg [15:0] s_writedata_reg;
reg [15:0] tdr_writedata_reg;
assign SRAM_DQ = ((cpu_tdr_select == cpu_sel) ? (~SRAM_WE_n ? s_writedata_reg : 16'hzzzz) : (~SRAM_WE_n ? tdr_writedata_reg : 16'hzzzz));
always @(posedge clk)
begin
if (reset_n == 0)
begin
s_readdata = 16'h0000;
s_writedata_reg = 16'h0000;
SRAM_ADDR = 20'h00000;
SRAM_LB_n = 1'b1;
SRAM_UB_n = 1'b1;
SRAM_CE_n = 1'b1;
SRAM_OE_n = 1'b1;
SRAM_WE_n = 1'b1;
end
else
begin
if (cpu_tdr_select == cpu_sel) // CPU
begin
s_readdata = SRAM_DQ;
s_writedata_reg = s_writedata;
SRAM_ADDR = s_address;
SRAM_LB_n = s_byteenable_n[0] | s_chipselect_n;
SRAM_UB_n = s_byteenable_n[1] | s_chipselect_n;
SRAM_CE_n = s_chipselect_n;
SRAM_OE_n = s_read_n | s_chipselect_n;
SRAM_WE_n = s_write_n | s_chipselect_n;
end
else // TDR
begin
tdr_readdata = SRAM_DQ;
tdr_writedata_reg = tdr_writedata;
SRAM_ADDR = tdr_address;
SRAM_LB_n = tdr_byteenable_n[0] | tdr_chipselect_n;
SRAM_UB_n = tdr_byteenable_n[1] | tdr_chipselect_n;
SRAM_CE_n = tdr_chipselect_n;
SRAM_OE_n = tdr_read_n | tdr_chipselect_n;
SRAM_WE_n = tdr_write_n | tdr_chipselect_n;
end
end
/********** TDR Host *************/
reg perform_sram_test;
reg [3:0] sram_test_state;
localparam waiting_to_start_sram_test = 0;
localparam start_sram_test = 1;
localparam sram_wait = 2;
localparam sram_end_read = 3;
reg [7:0] sram_wait_state_counter;
reg [31:0] sram_checksum;
reg [19:0]local_sram_address;
task enable_sram_read;
input [31:0] sram_index;
begin
sram_chipselect_n = 0;
sram_write_n = 1;
sram_address = sram_index;
sram_read_n = 0;
sram_byteenable_n[0] = 0;
sram_byteenable_n[1] = 0;
end
endtask
task disable_sram_read;
begin
sram_chipselect_n = 1;
sram_write_n = 1;
sram_address = 20'hzzzzz;
sram_read_n = 1;
sram_byteenable_n[0] = 1;
sram_byteenable_n[1] = 1;
end
endtask
// Manage SRAM verification
always @(posedge clk or negedge reset_n)
begin
if (reset_n == 0)
begin
perform_sram_test <= 1;
sram_test_state <= waiting_to_start_sram_test;
sram_wait_states <= 3;
end
else if (clk_en)
begin
if (chipselect && ~write_n && (address == 6))
begin
perform_sram_test <= 0;
end
if (chipselect && ~write_n && (address == 8))
begin
sram_wait_states <= readdata;
end
case (sram_test_state)
waiting_to_start_sram_test:
begin
if (perform_sram_test == 0)
begin
local_sram_address = 0;
sram_wait_state_counter = sram_wait_states;
sram_checksum = 0;
sram_test_state <= start_sram_test;
end
end
start_sram_test:
begin
enable_sram_read(local_sram_address);
sram_test_state <= sram_wait;
end
sram_wait:
begin
sram_wait_state_counter = sram_wait_state_counter - 1;
if (sram_wait_state_counter == 0)
begin
sram_checksum = sram_checksum + sram_readdata;
sram_test_state <= sram_end_read;
if (sram_readdata != 0)
begin
int_sram_address = local_sram_address;
int_sram_data = sram_readdata;
end
end
end
sram_end_read:
begin
disable_sram_read();
local_sram_address = local_sram_address + 1;
if (local_sram_address <= 20'h3ffff)
begin
end
else
begin
fire_int <= ~fire_int;
end
end
default:
begin
end
endcase
