21457 Discussions
Same PCB for the two CY4 FPGAs EP4CGX150CF23C8N & EP4CGX30CF23C8N
byisrael
In order to support one PCB the two CY4 FPGAs EP4CGX150CF23C8N & EP4CGX30CF23C8N,
Need to connect additional I/O pins of EP4CGX30CF23C8N (see below) to GND/VCCINT (1.2V)
I compile EP4CGX150CF23C8N with Migration to EP4CGX30CF23C8N, as expected at the project.pin report the pins connected to GND/VCCINT for example:
my question is if I assembled EP4CGX30CF23C8N and pin H16 (for example) connected to VCCINT(1.2V) , is it ok or Should I add serial resistor to the VCCINT pins in order to disconnect it when I use the EP4CGX30CF23C8N?
Thanks & Best Regards,
Israel Ben-Yeda
AqidAyman_Intel
Hi Israel Ben-Yeda,
It is not mandatory. You can refer to the link below for more details about this issue.
When migrating devices that have overlapping I/O and power pins, how...
Aqid Ayman
FvM
Generally, supported device migration doesn't require jumper resistors or similar, GX30 IO pin should have no problems to connect to VCCINT.
Frank
AqidAyman_Intel
Hello Israel Ben-Yeda,
If you plan to use those pins as GPIOs, then you may add the resistor and put DNI.
byisrael
I don't need to use those pins as I/Os, so I don't need the resistor?
GX30 IO pin should have no problems connecting to VCCINT?
Israel Ben-Yeda
AqidAyman_Intel
For me, it is a good practice to add additional resistor to the I/O pins even if you are not using it as it is connected to VCCINT.
byisrael
It’s “good practice to add additional resistor “ or mandatory?
Because it complicates the layout and can also hurt it (Hits VCCINT's polygon continuously),
Israel Ben-Yeda
AqidAyman_Intel
Hi Israel Ben-Yeda,
Aqid Ayman
