21615 Discussions
Sampling voltages inside FPGA
Gyud0
Hey,
I would like to know how can I sample some inside FPGA's voltages? There are some internal ADCs that I connect them and read the samples from them?
For example,  The FPGA's supply voltage.
Thank you very much
idemosaic
可以的,使用FPGA自带的温度传感器IP,配合Nios程序即可读取6个FPGA的供电电压和2个ADC输入电压。。。
ak6dn
Valued Contributor III
That would totally depend on which FPGA you are referring to, and you don't say at all.
Generally speaking this is not a feature FPGAs provide.
Gyud0
Hey,
my FPGA is Cyclone v
JonWay_C_Intel
Hi @Gyud0
For CycloneV, there is no Voltage/Temperature sensor circuitry/IP.
Only Arria10 and Stratix10 devices has it.
Gyud0
Can you give me the IP's name for the Arria10 and Stratix 10?
thank you
