Programmable Devices
19846 Discussions
Setup timing violation
Should I just split the combinatorial logic at line 15 of the following verilog module or https://github.com/promach/internal_logic_analyzer/blob/master/rtl/check_data.v#l15 across several registers ?
https://alteraforum.com/forum/attachment.php?attachmentid=14127&stc=1
`include "define.v" module check_data (clk, data_out, data_in, test_failed); // verifying the memory (circular buffer) read and write processes input clk; input data_out; // memory output input data_in; // memory input output reg test_failed = 0; wire data_out_is_valid; always @(posedge clk) begin if(((data_out + `MEMORY_SIZE + `ALIGNMENT_DELAY) != (data_in + 1)) && data_out_is_valid) // due to "delay.v" test_failed <= 1; end assign data_out_is_valid = (data_in >= `MEMORY_SIZE + `USER_HOLDOFF + `ALIGNMENT_DELAY) && (data_in < `MEMORY_SIZE + `MEMORY_SIZE + `USER_HOLDOFF + `ALIGNMENT_DELAY); endmodule
Your screen cap is too small to see, but you should certainly perform some of those calculations and comparisons outside of the always block in their own assign statements.
So you could say
assign data_out_calc = data_out + `MEMORY_SIZE + `ALIGNMENT_DELAY;
and do a check of just data_out_calc in the if statement.
You could also do something similar for the righthand side of the if statement comparison check.
OK.
By the way, I found out what went wrong with my setup timing violation. It is due to my mistake in timing constraint xdc file. My system clock is 1Ghz
