Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Shared HPS pins pin planning on Arria 10
Hi to all
I am working on HPS project in Arria 10 SX 320
I have instantiated a SPI interface on shared pins and I would place pins with pin planner (the pins are dedicated to HPS and not shared to FPGA)
On my qsf on brackets there is the name of hps pins
set_location_assignment PIN_J18 -to spi_rhea_clk (SPI_M0_CLK)
set_location_assignment PIN_H16 -to spi_rhea_cs (SPI_M0_SSN)
set_location_assignment PIN_H17 -to spi_rhea_di (SPI_M0_MISO)
set_location_assignment PIN_J19 -to spi_rhea_do (SPI_M0_MOSI)
This location pinout are compliant to Arria 320 SX pinout but in the plan stage I've an error ,
The error means that cannot place the pins on the pin location
For example :
Error(175020): The Fitter cannot place logic pin in region (84, 97) to (84, 98), to which it is constrained, because there are no valid locations in the region for logic of this type.
Info(14596): Information about the failing component(s):
Info(175028): The pin name(s): spi_rhea_di
Error(16234): No legal location could be found out of 1 considered location(s). Reasons why each location could not be used are summarized below:
Info(175015): The I/O pad spi_rhea_di is constrained to the location PIN_H17 due to: User Location Constraints (PIN_H17)
Info(14709): The constrained I/O pad is contained within this pin
Error(175005): Could not find a location with: IO_FUNCTION of HPS_IO (1 location affected)
Info(175029): H17
Error(175020): The Fitter cannot place logic pin in region (84, 95) to (84, 96), to which it is constrained, because there are no valid locations in the region for logic of this type.
Info(175028): The pin name(s): spi_rhea_clk
Info(175015): The I/O pad spi_rhea_clk is constrained to the location PIN_J18 due to: User Location Constraints (PIN_J18)
Info(175029): J18
How is solve this problem ?
Best Regards
Did you check if the correct package is selected in Quartus?
