21615 Discussions
Signal Assignment Delay
I'm working on simulating my project within Altera Quartus 11, using ModelSim Altera. I'm using VHDL code to simulate the design.
I'm giving a signal assignment to one of the inputs, but my reference output on the same channel is roughly taking 6.5ns to update. I would post the waveform and schematic, but being a new member, i'm unable to.
The two signals i'm referring to are mux_vcc (input) and mux_test (output), which are both connected to the same channel. Although in my VHDL code i'm assigning mux_vcc (input) as 0, mux_test (output) is 1 at the very start of the simulation, and only becomes 0 6.5ns into the simulation.
I was wondering if someone would please be able to help me out in removing this delay, as one of the purposes of my circuit is to detect the first 1 bit, and this issue means i'm unable to confirm it's performance.
Any help would be greatly appreciated.
are you doing a timing/gate level simulation? 6.5ns sounds about right
--- Quote Start ---
--- Quote End ---
Yes, i am doing a gate level simulation, but i was looking for a way in which i could simulate the design without this delay.
just do an RTL simulation
--- Quote Start ---
--- Quote End ---
Ok, thanks for the help. I was wondering though, is it possible to do an RTL simulation with VHDL language, as i get this error when attempting this simulation:
Info: Start Nativelink Simulation process Error: NativeLink did not detect any HDL files in the project Error: NativeLink simulation flow was NOT successful ================The following additional information is provided to help identify the cause of error while running nativelink scripts================= Nativelink TCL script failed with errorCode: NONE Nativelink TCL script failed with errorInfo: NativeLink did not detect any HDL files in the project invoked from within "if ! { nl_postmsg error "Error: Run Analysis and Elaboration successfully before starting RTL NativeLink Simulation"..." (procedure "run_eda_simulation_tool" line 191) invoked from within "run_eda_simulation_tool eda_opts_hash"
Ignore my last post. I managed to find the solution to this in an old thread. Thanks for the help.
