21613 Discussions
Signal tap removal
Hi all
I have an easy question.
I compiled my design and then I appen signal tap analizer. It append to my design a new entity, "sld_signaltap:auto_signaltap_0".
I run my design, made my analysis and now I would like to remove the entity.
Well, I removet auto_signaltap_0.stp from my design, but the entity is still there.
Any hint would be appreciated.
Best regards
Phate
P.S. I use quartus2 10.1 web edition, so no incremental compilation or similar.
Quartus includes instance information for signaltap in your QSF. The best way to remove this from your design and QSF is to:
[1] remove the enable signaltap setting under the project settings
[2] run analysis & elaboration
And if that doesn't solve it, delete your /db and /incremental_db directories and try again.
