21602 Discussions
SignalTap problem.
EEren
FPGA (MAX10) connected to a microcontroller board. If I disconnect the board SignalTap runs good. If I connect the board back - SignalTap starts and immediately writes - Invalid JTAG configuration.
Obviously the microcontroller board affects a SignalTap work.
I checked with a scope all JTAG pins and all configuration pins during SignalTap run - seems all good, no spikes, no problems on pins .
What can cause the problem?
ShafiqY_Intel
Hi EEren,
Can you try jtagconfig command when Max 10 connected to microcontroller board?
(open Command Prompt ---> go to Quartus directory <Quartus installation directory>intelFPGA\18.1\quartus\bin64> ---> run jtagconfig)
Please send me he screenshot of the result.
EEren
The problem was CFG_DONE pin. It was connected to CPU pin configured as output. I don't know why but this pin affects Signal Tap flow.
ShafiqY_Intel
Hi EEren,
Have you able to solve this CFG_DONE pin issue?
Any solution you can share to community here?
EEren
I just configured this pin as input on the CPU side.
