21324 Discussions
Simple Verilog Question--Impossible?
I have a verilog file Intensifier.v. In it is a module with the following port list:
module Intensifier (
clk,
_reset,
intensifierInput,
intensifierOutput
Now I have a top level file named Main.v. In it I want to instantiate an array of instances of Intensifier.
If I code:
Intensifier [1023:0]intensifiers;
I get the error: "Intensifier is not a type"
I am not surprised I get an error, as I have not instantiated Intensifier using a port list.
So, in Main.v I code:
Intensifier intensifier(
.clk(clk),
._reset(_reset),
.intensifierInput(mainTestIn),
.intensifierOutput(mainTestOut)
This does not give an error, but it is only a single instance of Intensifier, not an array of Intensifiers. Also, I have assigned mainTestIn and mainTestOut to intensifierInput and intensifierOutput, and if and when I can create an array of intensifiers, I will want each Intensifier in the array to have different inputs and outputs.
To be able to use different inputs and outputs, in Main.v I instantiate an instance of Intensifier using a port list but without assigning some inputs and outputs:
.clk(clk),
._reset(_reset),
.intensifierInput(),
.intensifierOutput()
This does compile without errors, but I'm not sure how I'll code .intensifierInput and .intensifierOutput later, and I still don't have an array of Intensifiers.
To get an array, if, in Main.v, I now try:
intensifier [1023:0]arrayOfIntensifiers(
.clk(clk),
._reset(_reset),
Or if now, in Main.v, I try:
intensifier [1023:0]ArrayOfIntensifiers;
I get the same sorts of errors.
Is it possible to instantiate an array of Intensifiers in a similar manner as instantiating an array of reg:
reg [1023:0] myregs;
When I need to do this in VHDL, I use a for-generate statement. See if you can find the appropriate syntax for Verilog (or SystemVerilog).
Here's what it would look like in VHDL:
-- Some of these would probably be top-level ports ... signal _reset : std_logic; signal clk : std_logic; signal intensifierInput : std_logic_vector(1023 downto 0); signal intensifierOutput : std_logic_vector(1023 downto 0); ... g1: for i in 0 to 1023 generate u1: intensifier port map ( clk => clk, _reset => _reset, intensifierInput => intensifierInput(i), intensifierOutput => intensifierOutput(i) ); end generate; The syntax should be pretty similar. Do a search for generate in the Altera sopc_builder/ folder. I know I've seen examples in the Altera verilog code.
Cheers,
Dave
--- Quote Start ---
wire [1023:0] mainTestIn; //wire or reg
wire [1023:0] mainTestOut; //wire or reg
genvar i;
generate
for ( i=0; i<1023; i=i+1 )
begin
Intensifier inst_i (
.clk ( clk ),
._reset ( _reset ),
.intensifierInput ( mainTestIn ),
.intensifieroutput ( maintestout
end
endgenerate
--- Quote End ---
I think,you want like this.
Thank you Dave and Supal. You were both on the right track. Supal, your solution was almost perfect, but you forgot a block name. I added this in my final code, shown below, as "INSTANTIATE_INTENSIFIERS".
I really appreciate people helping each other out. So many folks seem to use the Internet for the purpose of putting others down.
Matthew
module Test1 (
//inputs
clk,
_reset,
testIn,
//outputs
testOut
input clk;
input _reset;
input [1023:0]testIn;
output [1023:0]testOut;
wire [1023:0]testOutWire;
assign testOut = testOutWire;
genvar i;
generate
for ( i=0; i<1024; i=i+1 ) begin:INSTANTIATE_INTENSIFIERS
Intensifier intensifier (
.clk ( clk ),
._reset ( _reset ),
.intensifierInput ( testIn ),
.intensifieroutput ( testoutwire
end
endgenerate
endmodule
Hi Matthew,
--- Quote Start ---
--- Quote End ---
You're welcome.
--- Quote Start ---
--- Quote End ---
This forum has managed to stay quite civil :)
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
Simple Concept : If we know something,we say otherwise we subscribe that thread. ;)
Pleased to help you.
How to implement this condition in verilog??
If input>500------> output= 500
If input<-500-----> output=-500
else --------------> output=input
This is my code for this:
module check( clk,input,output);
input clk;
input [15:0] input;
output [15:0] output;
reg [15:0] output;
always@(posedge clk) //negedge
if (input >= 16'h01f4)
output <= 16'h01f4;
else if (input <=16'hfe0c)
output <= 16'hfe0c;
else
output <= input;
endmodule
I don't known why i get wrong result!!!
Need for helping!!
--- Quote Start ---
module check(clk,in,out);
input clk;
input signed [15:0] in;
output [15:0] out;
reg signed [15:0] out;
always @ (posedge clk) //negedge
if (in >= 500)
out <= 500;
else if (in <= -500)
out <= -500;
else
out <= in;
endmodule
--- Quote End ---
Hopefully code will work now. ( too simple,isn't it? )
Problem :confused: : Operation was being performed as an unsigned one which is not your
requirement, it was performing 2's complement and then was
comparing.
Solution :cool: : Declared signals as " signed" and make value as signed "500 or 16'sd500"
( instead of 16'd500 ) right for comparison.
Note : Never give keyword name for declaring identifiers. :)
DEAR,
Thanks man!
I tried your code and it's ok.
But i don't know why when i didn't use "signed" to declare signals, it also is ok,however in >+500 and 0-500.
Anyway, thanks for your care!
Best regards!
