Hi
I want to modify memory content without compiling the complete project. But when I try to use 'Rapid compilation' option in "Settings-Compilation Process Settings-Incremental compilation- Rapic compile", it seems disabled. Is this device or FPGA related problem or do I have follow some steps to enable it? Thanks,Link Copied
I tried this with Cyclone3 Part (Full version- Quartus-12.1-sp1-32bit-windows) "greyed out" Same problem! - It starts compiling from Synthesis, map,,,etc. sr- Mark as New
you should do what you want directly: update the memory initialization files, go to Processing > Update Memory Initialization File, then go to Processing > Start > Assembler
