21592 Discussions
SoPC - VHDL questions
I ran into a couple of questions:
I'm building a new component for the SOPC.
It generated a template that seems to me not 'generic' VHDL
entity pio_TERAchip_data is
port (
-- inputs:
signal address : IN STD_LOGIC_VECTOR (1 DOWNTO 0);
signal clk : IN STD_LOGIC;
signal in_port : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
signal reset_n : IN STD_LOGIC;
-- outputs:
signal readdata : OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
end entity pio_TERAchip_data;
-> Here I haven't seen declaring a signal in a port (like in signal clk : in std_logic;)
Is this the same as:
"clk : in std_logic;"?
2nd question concerns and odd construction (I guess it's a casting, but I'm not sure)
readdata <= std_logic_vector'("00000000000000000000000000000000");
Why this " ' " behind the std_logic_vector? And why this rather diffucult construction?
wasn't it easier to write:
readdata <= (others => '0'); ?
Thanks in advance,
Luc
Good questions!
The word "signal" in the entity is used to distinguish the port as a signal rather than say a file.
It is assumed to be a signal if omitted, which in 99% of cases that I have seen it usually is!
http://tams-www.informatik.uni-hamburg.de/vhdl/tools/grammar/vhdl93-bnf.html#concurrent_assertion_statement
Has a great VHDL syntax browser.
As to the type cast attribute question, I have no idea why the template is coded as shown and I agree that your suggested way is much neater. :confused:
Maybe this is something to do with the rules used by the tool-set to automate code generation.
I would be tempted to modify the template to suit your coding style.
Do you mean I could 'probably' alter the code to the simpler version or should I leave as is.
Unfortunately it's not easy to read ....
Luc
I have seen an explanation of the std_logic_vector' thing before as sometimes you see string'("tally ho"). I can't find the explanation I came across but basically it is to explicitly specify the type of your literal e.g. "0000000" could be std_logic_vector or a string. Here obviously there is no doubt as to what type you want but if for example you had some function which was overloaded for string and std_logic_vector then you may need to ensure one or the other was called when you passed in your literal.
Bit of a vague explanation and sorry I can't find the proper reference for you. Basically I wouldn't worry about it and follow vernmid's advice instead.
Is this template something that will get frequently updated? If you have automatically generated code from say a state machine editor that gets updated every time you make a change to the state diagram then I'd leave it as it is. If it's just a starting point and you are going to manually maintain the file as you would any other VHDL file then change it so it makes sense to you. (others => '0') is like you suggest a much more generic and maintainable way of writing it.
I have a related problem.
A line from a test bench generated by the SOPC builder:
active_and_waiting_last_time <= std_logic'('0');
Ncsim doesn't like this. Here is the warning message:
"white space assumed after apostrophe [13.5]"
The same construct for std_logic_vector is accepted:
No warning or error for this line:
address_from_the_master_0_last_time <= std_logic_vector'("00000000000000000000000000000000");
Can anyone explain this? I don't like warnings that I don't understand.
What's your intention to use a qualified expression in this place? It seems meaningless here.
--- Quote Start ---
--- Quote End ---
As I mentioned, the code is generated by Altera tools. There are many meaningless qualified expressions in the code, but ncsim only complains for "std_logic'('0')" and "std_logic'('1')".
It seems to be legal VHDL code, so I don't understand the warning from Ncsim.
No warning from modelsim
Raise an issue with incisive?
