19206 Discussions
Source Code for Driver and Application for DMA Read/Write using PCIE Avalon-MM Design
Iam working on PCIE Avalon-MM Design using Arria 10 FPGA.
Iam using the example design from the below doc to perform the DMA transfer.
https://www.altera.com/en_us/pdfs/literature/ug/archives/ug-01145_avmm_dma-1.1.pdf
Iam testing this example design in Hardware using the application “altera_pcie_gui.exe” and the windows 64-bit driver for DMA Read/Write from the below link:
http://alterawiki.com/wiki/reference_design:_gen3x8_avmm_dma_-_arria_10
This application run read DMA (move data from system memory to the on-chip memory in the FPGA), write DMA (move data from on-chip memory to system memory), or simultaneous read and write.
is it possible to get the source code of this driver (altera_pcie_win_driver) and the application as we need to modify this driver to build our own application to perform similar DMA Read/Write.
Please let me know where can I find the source code for this driver software.
I'm also working on the same and need Linux driver code, application code for doing dma transfer between system memory and on-chip memory
Altera does not provide the Windows source code for the PCIe driver. The reference design and Linux source can be found from related links in the AN690:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an690.pdf
There is an example simple version source code from the following link that perhaps could be use as reference:
http://www.alterawiki.com/wiki/pci_express_in_qsys_example_designs
Please be aware, the material from the wiki page can be publish by anyone and it is provided as-is and is not supported by Altera.
nyusof
(This message was posted on behalf of Intel Corporation)
