Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Stratix IV GX transceiver transmit simulation
I am trying to simulate (with Mentor Questa) the transmit part of a Stratix IV GX transceiver.
I defined the protocol as basic and I disabled the 8b10b part.
Whatever I set on the txdatain port, I get the tx signal of the transceiver toggling in the same sequence. I get a sequence is: 1111011000111101100 (that could look like a K.28.6 in 8b10b)
I want to use the transmitter to generate a high speed signal without any protocol. (I don't want/need clock recovery on the receiver side). So I just want the value on txdatain to be serialized.
Transceiver vhdl file is attached.
Did any run a simulation successfully in such a setup?
raph
Here is my mapping:
Trans_inst : Trans port map (
cal_blk_clk => Clock_125,
pll_inclk => Clock_125,
reconfig_clk => '0',
reconfig_togxb => "0000",
rx_coreclk => Clock_125_bus,
rx_cruclk => Clock_125_bus,
rx_datain => dataline,
rx_locktodata => "00",
rx_locktorefclk => "11",
tx_coreclk => Clock_125_bus,
tx_datain => "1111111111111111111111111111111111111111",
reconfig_fromgxb => open,
rx_clkout => open,
rx_dataout => open,
tx_clkout => open,
tx_dataout => dataline);
PS2: I get the following message while simulation, I doubt it is related:
# ** Warning: (vsim-8683) Uninitialized out port /tb/Sata_trans_inst/Sata_trans_alt4gxb_component/cal_blk0/nonusertocmu has no driver.
# This port will contribute value (U) to the signal network.
# ** Warning: (vsim-8684) No drivers exist on out port /tb/Sata_trans_inst/Sata_trans_alt4gxb_component/ch_clk_div0/dprioout(99 downto 94), and its initial value is not used.
# Therefore, simulation behavior may occur that is not in compliance with
# the VHDL standard as the initial values come from the base signal /tb/Sata_trans_inst/Sata_trans_alt4gxb_component/wire_ch_clk_div0_dprioout(99 downto 94).
Highlighted
Re: Stratix IV GX transceiver transmit simulation
Nevermind, I added the gxb_ powerdown signal and it is ok now....
r.
