21102 Discussions
Stratix10 cannot be discovered as PCIE device in ubuntu
Yanhan
Hi, I tried the example design in UG20170 https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/avmm_stratix10_hard_ip+_ug.pdf.
I installed the driver and load the example design to the device successfully. However, when I use lspci to search the device, it cannot be discovered.  And the test program didn't run as expected becauce the pcie device was not found.
The environment is Ubuntu20.4. The device is Stratix10 1SG280LN2F43E2VG.
SengKok_L_Intel
After you program the SOF to FPGA, did you reboot the host for it to perform the PCIe link training and enumeration?
Regards -SK
Yanhan
Yes I reboot the host, but it still cannot work.
Yanhan
Thank you for replying. I reboot the host but it still cannot work.
SengKok_L_Intel
Could you please add the following signals into the signal tap to check the PCIe link status?
  1. ltssmstate[5:0]
  2. lane_act[4:0]
  3. link_up
  4. currentspeed[1:0]
  5. pin_perst
  6. npor
Regards -SK
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
