i get counter and counter_tb source code from asic world.
However i get an error when compiling the counter_tb: Error: E:/ModelSim_Project/Counter/counter_tb.v(48): near " ": syntax error, unexpected non-printable character 0xa0. It seems no syntax error to me. Pls have a look on it. The source code is attached. ThanksLink Copied
--- Quote Start --- i get counter and counter_tb source code from asic world. However i get an error when compiling the counter_tb: Error: E:/ModelSim_Project/Counter/counter_tb.v(48): near " ": syntax error, unexpected non-printable character 0xa0. It seems no syntax error to me. Pls have a look on it. The source code is attached. Thanks --- Quote End --- Hi, I assume there is a tab or space behind the keyword initial in line 48. Kind regards GPK
you are right. really unbelievable. thanks a lot
